help!installtion of webi 2.6
help!
i installed webi 2.6 in 2k3 server,and i had copied the p4 patch to server/jre/bin/ ,and make virtual dir /wi and /wi/wiadmin fellow the documents.
but now ,when i open http://localhost/wi,to press the login button,it show me …iswi.dll/wigeneartor/… not found(404 error).
but i open the bo broadcast admin tool ,it works normally.
the os ver:win2k3 server
iis:6.0
webi :2.6
bo:5.12
i know webi 2.6 is not comfortable for 2k3 server,but i had instaled webi 2.6 in 2k3 successfully in an other PC!the work steps are same to above!
i don’t know what the problem is,anybody can tell me what shall i do when it happened in 2000 server?
yuwanggedou2 (BOB member since 2006-05-20)
:idea:
Do you verified after installing BO that IIS is running ?
Generaly you must start it.
A good idea is to re-boot your server.
Cheers,
bogdan agape :fr: (BOB member since 2004-09-08)
