having problem to display bmp image
Hi guys,
using BOXI 3.1 webi.
here is the bit map url: =“boimg://image.png”. when i use this one in new report its not showing image returning as text where as the existing reports which are using this one working fine.
any suggestions greatly appreciated.
Thank you,
PV
sownu (BOB member since 2009-08-27)
Did you verify the Cell Properties are set to read the Cell Content as “Image URL?”
Properties
Display
Read Cell Content As ~ select Image URL
REB01 :us: (BOB member since 2004-11-29)
thank you its solved my problem.
-PV
