Hash Values in BODS
Hello Experts,
I am a newbie to Data Services. We are using Data Services XI 3.0 Premium. I was given a task to identify duplicates by using hash values so that there is no loss of data and at the same time we can identify the duplicates. I was able to find that functionality in Oracle. But client wants the functionality in Data Services, before it loads into Oracle. I looked everywhere, couldn’t find the right information. Help would be really appreciated. Please let me know if any further information needed.
Thank you for going through my post. I really appreciate your time.
Thank you,
Sandeep.
sandeepgandam (BOB member since 2013-04-29)
Would you give some example on what you would like to achieve? I am not exactly following what you mean by Hash Value?
I’m not quite sure why you would create a hash value to compare rows but if that’s what you have to do…
The closest I see is the double_metaphone() function. I’ve never used it so it may not be what you want.
Hello Ganesh,
Thank you for responding. Hash value is nothing but, some number or string which gets generated based on the values we feed.
My purpose is to generate a string or numeric value for each row which is inserted into a table in database. That way I can identify the duplicates. I am not sure if I have explained it the right way. Here is a nice reference just in case: http://blogs.msdn.com/b/sqlsecurity/archive/2011/08/26/data-hashing.aspx
Client wants me to do hashing in BODS before the data hits the database.
Please let me know if anything needed.
Thank you,
Sandeep.
In your SQL Server DataStore, import the HashBytes() SQL function.
You can then use it throughtout Data Services.
Nicolas Hadj-Blaha :new_zealand: (BOB member since 2005-03-10)
Thank you Jim and Nicholas. I really appreciate your time. I will try to use sql function in BODS and see if it works.
Thank you for your help.
