We are trying to create a calendar that when you click on the date the appropriate results from a query are displayed. Has anyone created the script for this to run?
Or does this work at all with BusinessObjects using mscal.ocx?
Any suggestions or scripts would be greatly appreciated…
Add the reference from c:\Program files\microsoft office\office1X\mscal.ocx.
Add the control to the toolbox.
Addd the calendar control to the form.
From a report create a criteria range with prompts "StartDate: and “EndDate:”
busobj.ActiveDocument.Variables(“StartDAte:”).Value = Calendar1.Value
busobj.ActiveDocument.Variables(“EndDAte:”).Value = Calendar2.Value
If the field that you are applying the criteria to is a Date field Type, then you need to Right Click on the Data Tree and EDIT DATA Provider.
C;lick on the Show SQL button
Convert the dates using the SQL Cdate function.
If not, BO passes the calendar date values as text. Which if you were selecting “01/01/01” to “01/01/03” would give you the following:
01/01/01
01/01/02
01/01/03
instead of the full set of date for the 3 years.
I use B0 5.18
rh.RHCHGD,
sum(rh.RHRCAM),
count(rh.RHRST),
glperiods.CMFQTR,
glperiods.CMFWEK,
Table__3.RSTDESC
FROM
glperiods,
rh, REserve Types RST Table__3
WHERE
( rh.RHRST=Table__3.RSTCD1 )
AND ( rh.RHRSBT=Table__3.RSTCD2 )
AND ( glperiods.Hundredyear=rh.RHCHGD )
AND (
glperiods.Fdate >= cDate(@variable(‘StartDAte:’))
AND glperiods.Fdate <= cDate(@variable(‘EndDAte:’))
GROUP BY
glperiods.Fdate,
rh.RHACI#,
rh.RHRST,
rh.RHRSBT,
rh.RHCC,
rh.RHCHGD,
glperiods.CMFQTR,
glperiods.CMFWEK,
Table__3.RSTDESC
