Handling of accents, ñ, Ö, ü ... and more.
Hi everyone,
I have source tables with accents, ñ, Ö, ü, ä, Ä, é, è, ï, ô, ê, Ø, ã, â, ç, õ, ô, ö, á, ú, ó, í.
When I pass the data to a destination table does not recognize any of these characters. How I can do to take them as is?
Thanks a lot for your help.
fra_03 (BOB member since 2011-03-16)
Another point is that this happens because the source tables are SAP and target tables are Oracle.
Could it be that Oracle is missing something?
Total Thanks!
problem could be because of incorrect NLS_LANG setting for the oracle client on the Job server machine
depending on territory and language set the NLS_LANG correctly and restart the DS Service and run the job
An Oracle step-by-step guide.
https://wiki.sdn.sap.com/wiki/display/BOBJ/Multiple+Codepages
I changed the settings DSConfig, Regedit, Datastore … What could be missing?.
Attached image of the changes I made.
Thanks so much for all the contributions.
set the datastore code page and server codepage to cp1252 and see if that works
Wonderful!, That was!.
I’m Happy, Thank you so much!.
This forum is best.
had the same exact problem and it worked for me too, thank you
alespissoto (BOB member since 2012-10-05)
