Handling Message box
I am using BOXIR2(Deski reports)
I am scheduling the reports as html files using batch files,the report has to refresh and generate early morning at 5 O’clock.
I am using Freehand sql as Data Provider.
My concern is some time there is no data to fetch message appears and hold it to schedule the report when there is no data to return by the query.
I would like stop this message to appear.
Thanks in advance.
Thanks & Regards,
Mohammed Pasha.
mdpasha (BOB member since 2008-04-08)
Did you search BOB with keyword supress…
See here
Thanks A lot!!!
Thanks & Regards,
Mohammed Pasha.
