Group Level Objects Scheduling and .txt format missed
Dear All,
Please let me know how to do the group level scheduling. For example, we are having 100 reports on the folder, if we are doing the schedule based on the object package, the available output format is only Desk-I. There's no more formats are available other than this. Can you please let me know how to do this?
  1. After installing the BO in the local system, the .txt output format is not available from the list while scheduling the report.
Please suggest the above scenarios.
Shankar
silv_shankar :india: (BOB member since 2006-04-03)
Bulk scheduling is possible through publication only.
We have only three formats Microsoft Excel, Adobe acrobat & Web Intelligence.
krishnak :india: (BOB member since 2008-06-27)
Thanks for the solution and reply. I have created the Publication and am not albe to select the source object more than 1 (able to select 1 report in the source tab). Please let me know how to select more than a object.
Shankar
On which version are you ? A publication with several reports is only possible from R3 (not in R2)
RikDeclercq :belgium: (BOB member since 2006-09-28)
