We are using SQL Server 2005 as the front end database. When we use the aggregation function STDEV() in a measure, we donot get a group by clause in the sql generated by WebI for this measure.
The WebI Sql generation treats STDEV() as a single row function.
However, if other aggregated measures (e.g. SUM, MAX) are included in the query panel along with the STDEV() measure, it simply includes STDEV() in the Group By clause which is wrong.
SELECT
dbo.DIM_A.CUST_NB,
STDEV(dbo.FACT_f.NUMERIC_VAL_1),
MAX(dbo.FACT_f.NUMERIC_VAL_2)
FROM
dbo.FACT_f INNER JOIN dbo.DIM_A ON (dbo.FACT_f.CUST_SK=dbo.DIM_A.CUST_SK)
GROUP BY
dbo.DIM_A.CUST_NB,
Could anyone tell me how the sql can be correctly generated for STDEV() ? Is this a bug?
I checked the link. It’s gr8. I tried to search first but couldn’t retrieve the link (probably because I didn’t select All topics).
But would just want to make sure if this is a .prm file in the odbc directory (probably odbc.prm). I donot have admin access to the system. So I need to mention the specific file in the directory when requesting the administrator.
