BusinessObjects Board
Google spreadsheet connection with xcelsius
I am now trying and trying since hours but I can’t find a solution. :hb:
I want to use a published google spreadsheet as a data base. Mainly with the purpose to save made changes.
This was the main idea:
Now I am getting the same result than the writer of the blog. Does somebody has an idea how to solve the problem with “Security error” when assessing the url?
It is really urgent and using google spreadsheet would be the perfect solution for my problem.
Thanks for your time and answers.
JOGE (BOB member since 2012-06-27)
I just figured out (after almost trying everyhing) that the connection works in the preview mode within xcelsius.
Does anybody know where the problem could be?
HEEEELP!
Years later I want to establish the same! Have you done your project with succes?
I also would like to connect my Google spreadsheet with Dashboard Design…
:roll_eyes:
TurningPointHolland :netherlands: (BOB member since 2006-09-06)
