Some of these have been addressed in BI4.0, so Iâll address each of these individually.
Webi has Page mode, which allow Print Preview, and more. You can see how it will look printed, and work on it at the same time. This is much better than Print Preview. 8)
Webi 4.0 has many print option. 8)
This seems to work fine in 4.0. 8)
This is still missing in 4.0.
It doesnât prompt. It simply keeps the filter, and you can easily delete it if you donât want it. 8)
This is still true in Webi 4.0. But this is a very minor issue.
This feature is now available in 4.0. 8)
Still true. I wish they would fix this.
Still true. Documents must be exported one at a time.
Still true. I, too, miss this feature. But the more I work with contexts, the less I miss this feature. It is very useful for beginners.
Iâve never seen this behaviour. In 4.0, the LOV doesnât populate until you refresh it.
Still true. I prefer using boolean variables. Itâs easier to edit them as variables.
Still true. Still frustrating.
Iâm not sure what this means. I am able to create filters on measures.
You can do this in 4.0. 8)
Still missing. But this is a feature that I never used. I prefer to do it in the universe. That way, I can do it once, rather than always doing it at the document level, over and over again. 8)
This is still true. I had to test this, as Iâve never tried this before.
Still true. You can use the RelativeDate() function to accomplish the same thing.
Personal DPs can be marked as non-refreshable, but not universe DPs.
This is fixed in 4.0. 8)
Webi 4.0 has made some improvements, as you can see, to some of the missing functionality. Thatâs the good news. The bad news is that the new interface is kludgy and hard to work in. It has has some new bugs, and missing features from Webi 3.1. For example, you can no longer a single query from the query panel. And Data Tracking doesnât work unless you set Alternate Row Shading to 1 (This is scheduled to be fixed in SP04).
MichaelWelter
(BOB member since 2002-08-08)
