Global variable is not being evaluated for the first record.
I created a global variable.
I created a group on that variable.
The variable is not being evaluated for the first record. When I display the value, its showing as blank and from 2nd record its working fine.
Any idea, Why the variable is functioning like this?
Thanks in advance.
Gowtham Sen.
GowthamSen :india: (BOB member since 2006-08-31)
Check to see if the column you’re evaluating is null. You’re formula will fail if it encounters null data.
AnthonyJ :philippines: (BOB member since 2006-06-30)
Thanks a lot Anthony.
You are right. There are null values. I corrected it now. Its working fine.
Thanks once again. :wave:
Gowtham.
