Hi all,
I’m tring to get ‘*’ to show up in a LOV by overriding the LOV SQL. I’ve got it working if the LOV data type is char but not if the data type is numeric.
SELECT DISTINCT
to_char(GASVALVE.GASVALVETYPE)
FROM
GASVALVE
union select ‘*’ from DUAL
generates the correct LOV in Designer when I click the Display button.
i.e.
1
2
3
4
etc
however when I try and use the LOV in Webi, the LOV shows (–No Value–). Any tips on how to get ‘*’ or ‘ALL’ into a LOV consisting of numeric data types?
Thans for posting judia but I’ve successfully used the override LOV sql method, outlined in the FAQ you linked to, for universe objects that are of character datatypes. Using the exact same method fails if the objects are a numeric datatype. I’m not sure if I have to do anything extra in this scenario.
Cheers
Keith
i have understood what you are trying to say.
kethiL, since you are using a measure object, you have to unite with only measure object.
ex: union select 0000 from dual
