German Address cleanse:Delivery point directories not found
I have got the folder 51047069 from SAP Marketplace for German address cleanse. THere are 17 files inside it. I copied the files to C:\Program Files (x86)\SAP BusinessObjects\Data Services\DataQuality\reference_data location but when when I run the job I get below error. please help.
Transform <Germany_AddressCleanse>: : [Delivery point directories not found. Update directories or certification will be disabled]
:cry:
BODSDW (BOB member since 2011-01-19)
Anyone please?? Werner?
Can’t accept to believe that there is no one who has the solution :hb:
is it necessary to have ‘Allworld’ address directory mandatory even though I need to only clean German address data?
Finally, I downloaded Blueprints and changed the source and target options as desired it works fine now.
Hi BODSBW,
I got the same error using Australia Address cleanse… can you please let me know which blueprints that I should look for? or where i should change the source and target options.
Thanks for your help.
chauh :australia: (BOB member since 2010-12-23)
I got the same error for German Address Cleanse.
I imported Blueprints for Germany but still no clue where to find source and target option you mentioned.
What did you mean by source and target options.
Thx,
Sascha
smilicevics@gmx.net (BOB member since 2015-05-04)
Blueprints are available at below location on SAP -
http://scn.sap.com/docs/DOC-8820
I believe you can use ‘Global’ blueprint for australia and set the options accordingly in transforms.
Source and Target simply meant the Input and output in your address cleanse transform.
Hi Experts,
Facing Same problem…Would you please help me on the below scenario POSTED…INDIA ADDRESS CLEANSE
Below is the Source data, which has complete address in one single column, however Client wants
this address column into 3 columns as Add_line1, Add_line2, Add_line3, City, Region, Pincode :hb:
Would somebody please help me…on this
This Address has different formats: For exampleÂ…
  1. Few address has ‘,’ COMMA separated
  2. Few with SPACE separated
  3. Few with NOTHING
Nos
Source
1
55444, 212th Main, ITI L/O Mallathahalli Bnaglore-42145
2
18446 B,Ranka Colony,Bilekahalli,Bannarghatta Road,Hyderabad-143121
3
#301, 65th main, 125th Cross, Cross extension, Vivek Nagar,Hyderabad-874545
4
Plot # 542,BHS Layout,101th A Cross,184th Main,SanthnagarBommanahalli,Bangalore-1245454
5
#0542427, GF, 24540th Main,455th Cross, Sector 1, HSR Lay Out,Hyderabad-624515
6
King Apartment, Sumana Nagar, Near 5454 Main Hospital, Vijay Nagar, Marol-Mahroshi Road, Andheri East, Hyderabad 400059.
7
Residency Jet Mumbai,Opp. Techniplex Compamy Off S.V.Road, Goregaon (W), Pune
8
Pop & Ben Corporate Stay,B706, 107th Floor, Joy Valencia.Near Majas Bus Depot Jogeshwari East Thane
9
Sao Ashok Nagar, Borla, Govandi Hyderabad 400088
10
Plot No.54534/6Yet Home Colony Opp.Of Maharaja LightKarvenagar
11
Room No.2orgage ColonySr.No.487/8DAzadwadiKothrudHyderabad545745
12
Sr.No.14352/149454Building No-202Ajmera ColonyPimpriHyderabad-411018
aamarnath (BOB member since 2015-06-03)
Hi Experts,
Facing Same problem…Would you please help me on the below scenario. I POSTED…INDIA ADDRESS CLEANSE
