Is it possible to generate Electronic Data Interchange (EDI) files (ANSI X12 spec 837, Professional Claim) using Crystal reports or Webi. ? please advise if anyone worked on it.
sreenu Puli (BOB member since 2011-07-27)
[Moderator Note: Moved from Semantic Layer / Universe Designer to General Discussion]
I’d imagine it’s possible. At the very least it can collate the data into a text file then you can change the format of the output with a simple save as operation.
Try creating a basic file from spreadsheet data first before putting too much effort into a fully-sourced Webi report.
Thanks MARK but Customer looking from BO.
Yes, Webi is part of BO…
