function EXEC() returns 0403-006 Execute permission denied.
When I call any Unix command via the Business Objects Data Services function EXEC() I get “0403-006 Execute permission denied.”.
When I execute the same command at the Unix prompt it works correctly
bryantm :australia: (BOB member since 2010-06-21)
With the same user the al_jobservice process is running under?
Using the exec(’/bin/ksh’, ‘xxxx’, 8 ) syntax?
thanks, I have now solved the problem,
previously I had:
print(exec(‘ksh’, ‘whoami’, 8));
which returned:
1: ksh: whoami: 0403-006 Execute permission denied.
now I have:
print(exec(‘whoami’, ‘’, 8));
returning:
0: d02adm
so the unix command is now executing correctly in BO
