system
May 15, 2004, 12:39pm
#1
A “downloadable” has been posted in BOB’s Downloads that shows the percentage of Full Client and Webi reports present in a Business Objects reporting system. Any discussion should take place in this topic.
BOB Downloads (BOB member since 2003-05-05)
system
June 24, 2004, 11:10am
#2
What universe I have to use to view this report. It is very good one. I think it will help me a lot.
Thanks and regards
patra
patra_bt2004 (BOB member since 2004-03-01)
system
June 24, 2004, 11:37am
#3
I think it will work in Free Hand SQL as per the comment given by the author…
Sridharan (BOB member since 2002-11-08)
system
June 24, 2004, 11:03pm
#4
I have built this report using Free Hand SQL so no universe is required. Please follow the instructions in the document and you are all set to go.
JaiGupta (BOB member since 2002-09-12)
system
January 19, 2007, 11:55am
#5
Do We have Similar Kind of Utility for new verison of Business Objects.
