At the moment my deski users do noot have the drop down option to create a report using freehand sql.
I do not know where to go to grant this access.
Please help.
olut (BOB member since 2009-08-20)
Please help.
Depending on which BO version you use, you enable this feature to users either in Supervisor (BO version up to 6.5) or in CMC (BO version from XI).
[Moderator Note: Moved to CMC - Jansi]
Hey Nithya, thanks for the screen shot. It is the first time, I’m viewing something related to CMC.
Jansi (BOB member since 2008-05-12)
i have already gone into the deski advanced rights and granted the “use freehand sql” but still not coming up in the drop down.
@ olut: Does it come up if you login as an Administrator?
@ Jansi: You mean a screenshot of CMC in the forum right? and not CMC itself! The ease with which you solve queries, I am sure you would know the CMC functions in and out!
nithya_raj (BOB member since 2007-02-03)
Hi nithya_raj,
No it does not come up with the option when i login as Administrator
No need to login with Administrator to use “Use Free-hand SQL” is the right option for your requirement.
Can you attach the rights you have given to user on DesktopIntelligence Application?
Arjun (BOB member since 2008-07-28)
