I have a variable ([Run Time]) that’s supposed to show the number of hours between when an order was written (for the sake of brevity I’ll call that [A]) and current time ([B]). This is my current formula:
=(((DaysBetween([A];[B]))*1440)
+(ToNumber(Substr(FormatDate([B];"HH:mm:ss");1 ;2))
-ToNumber(Substr(FormatDate([A];"HH:mm:ss");1 ;2)))*60
+(ToNumber(Substr(FormatDate([B];"HH:mm:ss");4 ;2))
-ToNumber(Substr(FormatDate([A];"HH:mm:ss");4 ;2))))/60
First, can you confirm that the formula looks OK? If there’s a simpler way to do that I’ll take it.
Here’s the frustrating part: It’s been working just fine. It worked correctly when I ran the report at 1:06pm today. But when I ran it at 4:18, the calculations were off. If the formula is correct, is there anything that could’ve happened on the back end to affect the results?
It’s currently 12/15/2015 17:36, and my report is showing [Run Time] for an order written at 12/14/2015 17:25 is 48 hours, when it should be 24.
I did double check =CurrentDate() and it’s correctly displaying the current date, & time when I format it to do so.
thriftjl (BOB member since 2014-11-07)
