Formula for Not Inlist?
Please help me with the formula for.
Accounting Period Not In (0999;0900)
I created a formula like:
Not([Accounting Period]) InList(0999;0900)
But gives me error:
The expression or sub-expression at position 298 in the ‘Not’ function uses an invalid data type. (WIS 10037)
How do I create a formula for not inlist?
GNK_BO (BOB member since 2007-07-17)
=Not([Budget_Period] InList (1,2))
Or if it’s a number, then also you can try -
=[Budget_Period] <> (1,2)
Truely speaking I haven’t tried any of these, but you can just try and let me know if it’s not working, then I will try to create one at my end.
Edit - Are you trying to filter those values or what actually you are looking for? That would help me to create the situation at my end.
Desk-I code:
=If Not(<Budget_Period> InList (1,2)) Then 1 Else 0
Web-I code:
=If(Not(<Budget_Period> InList (1;2));1;0)
P.S: Not sure whether Web-I code is right. Try it out.
In your modified code, you misplaced one right parenthesis.
Not In ( ‘AAAA’,‘BBBB’,‘CCCCC’ )
this works for Oracle, note the comma separator
Xavier :ireland: (BOB member since 2006-12-18)
Hi Aniket,Jansi,xavier
Thank you all for your quick reply.
I have tried Aniket first code and it worked for me … so did not went to try other codes.
But really thanks for helping me
You guys are of great help…
