formatting in Design Studio
I’am playing around a bit with Design Studio. I have added a crosstab but I can’t figure out how format the dimensions (columns and rows). Do I need css or something else ?
RikDeclercq :belgium: (BOB member since 2006-09-28)
yes you need CSS. Any simple modifications, even a font size change need CSS…“No idea what is SAP thinking…” :shock:
Look at this document.
You need to create a custom css and then assign that css to crosstab or add your code in the application CSS
hope it helps
rajx72 (BOB member since 2006-08-02)
Thank you ! :+1:
