Formatting data at Universe Level
Hi All
I have an Object at Universe level.
InvoiceDate (its type Character) and shows date in format yyyy.mm.dd
How do I format it so its dd/mm/yyyyy as I want it to use it as a Report Prompt. Have tried amending type to date but it make ALL the InvoiceDate dates to 01/01/01
Many thanks
Zahed
Sims786 (BOB member since 2006-04-04)
show us the formula that gives you the 01/01/01
n8aktiv :de: (BOB member since 2018-12-29)
