system
1
Hello,
I need to format the phone number in this way 480-444-7212 from 4804447212.
The field in the database is Numeric.
When i go to format filed and go to Number tab i can’t see the option to do it over there.
please help me how to format the telephone number using formula may be…
Alluri
Rajua99
(BOB member since 2004-12-16)
system
2
can you do it on universe ?
convert it to char then add - into it ?
123-123-1234 is not a number format but a string.
Suma9898 (BOB member since 2006-08-30)
system
3
we are not usng Universes to create the reports.
can you tell me how to convert the number into string in crystal reports using formula…
Rajua99
system
4
Create a formula to display the phone number, something like:
Picture (ToText (TABLE.FIELD_NAME}, 0, “”), “XXX-XXX-XXXX”)
blair
(BOB member since 2006-11-17)
