FormatDate and an Alerter applied on a column
I have a column in a table of type date.
I have applied FormatDate([];“yyyy-MM-dd”) function on that column.
This column also has Alerter applied on it.
But Alerter does not works if we Format that column(FormatDate function).
When I remove this function,Alerter works.
Please suggest me appropriate solution.
Amruta
megha_musale (BOB member since 2009-09-02)
Try removing the alerter, apply the function and then add alerter.
It should work even if there’s an alerter on that column.
Srujana
srujanaj :india: (BOB member since 2010-02-10)
Is the alerter a comparison against a date field of some sort? A formatted date is really a string, which doesn’t compare the same way.
What if you just format the column (with cell formatting), without changing the values in it?
