I have a column with number and would like to format into dollar and cents. Last two digits are always cents. for example 345600 = 3456 $ 00 cents. 4567=45$ 67 cents.
pkommidi (BOB member since 2006-03-10)
Well, have you looked at the currency formats :? ?
Mak 1 (BOB member since 2005-01-06)
This field in database is a number field and we need to format dollars and cents. When i use the format, it always adds the 00 as cents.
Well, try creating a custom format?
If nothing else then try a formula like this:
=Substr(FormatNumber([number];"0");1;Length(FormatNumber([number];"0"))-2) + "$ " + Right(FormatNumber([number];"0");2) + " cents"
However, please note that the result is a string. It’s not a formatted number. It’s a string.
If we need to use them calculation, we better of converting them into numbers. Is it best to load into database column.
How about this output?
3456$.00
45$.67
I got this by applying, this format:-
0$.00
Then creating a “precision” variable / divisor of 100.
Doing anything else will no longer make them numbers, as in Mareks example.
When i format any number last two digits should be cents and rest should be dollars. For example 3456= 34.56 , 892=8.92 55000=550.00
You need to divide your value by 100 and store it in a variable. Then apply the currency format on it.
bbee (BOB member since 2010-03-09)
Then divide the number by 100.
Or am I missing something? :?
Yep :), if you divide the number by 100 and then apply the custom format, I suggested, then you will get the results that I described.
You can also create the variable as bbee described, then apply the format.
Obviously, you can’t have the “cents”, in words part for this to continue to be a number, as in your example, Marek.
