Is there any way to have the Format\Filters option into the toolbar, not as a menu option? I mean, as an icon
Schuster (BOB member since 2002-08-29)
I haven’t seen a parameter than can offer this.
But perhaps with a macro (.rea) , you can do this.
monoludo (BOB member since 2004-07-30)
yes, I was thinking in something like that, but how could I add an icon for that specific option to the standard toolbar for instance?
There are several utilities in BOB’s Downloads that customize toolbars.
Dwayne Hoffpauir (BOB member since 2002-09-19)
Yes, but the samples are always using VBA macros, I cannot find how to apply to the “onaction” the execution of an option from BO menu, like “Format\Filters…”; how can I call that menu option?
I just want to make sure we are not overlooking the obvious here. You are speaking specifically about adding a Format\Filters icon different from the “Insert Filter” little yellow icon available on the “Report Toolbar” - Yes?
jswoboda (BOB member since 2002-06-20)
yes, it is a different icon, the idea is to access directly to that menu option, Format\Filters… but I don’t know how to call it
Correct, the only way I know of to customize toolbars is using VBA.
Additionally, any menu item can be simulated by using the .Execute method for a command bar control.
Application.CmdBars(2).Controls("F&ormat").Controls("Fil&ters...").Execute
Thanks! it works
You’re quite welcome. I’m going to move this to the SDK forum, but leave the topic in Reporter as well.
