Fonts in Webi2 listings of universes
Has anyone else had the problem of the display fonts of the universes available (under ‘create document’) being mixed up under the ‘Compact’ display. The repository column is the main one where fonts seem to be bigger than the other columns and overlap with some of the other text. This is happening under IE4.01 and Netscape 3.02.
Jonathan
Project Leader
Global Medical, Regulatory and Product Strategy (GMRPS) IS
Check the monitor resolution and make sure it at least 800x600.
We have not seen the problem with Netscape. But be careful with IE 4.01 make sure you have the service pack loaded (SP1) otherwise the web panel for editing reports will not come up.
Sincerely,
Thomas Nather
Penske Logistics
email: Tom.Nather@Penske.com
Ph: 216-765-5787
Fax: 216-765-5666
“Cirkel, Jonathan D” jc14547@GLAXOWELLCOME.CO.UK 10/27 11:48 AM >>>
