Fomula Error
Hi Guys, I am currently building a reports and requires me to use the formula:
=If Iserror (<# measure>/<# measure>) Then “” Else (<# measure>/<# measure>)
Is my formula correct? I would like the cells with no values be blank and not NA or any other value.
Thanks a lot guys.
bi-bo (BOB member since 2009-12-11)
It should be
=If Iserror (<# measure>/<# measure>) Then 0 Else (<# measure>/<# measure>)
Then use format cell > number and use a space for equal to zero box
Or try using a formula like this:
=If Not(Iserror (<# measure>/<# measure>) ) Then (<# measure>/<# measure>)
Hi Guys, thanks! Both formula worked. :smiley:
Thank you very much.
