folding / unfolding Breaks
hello,
I have a problem with the ruptures in Webi XI 3.1
I have a cross-table with breaks and the breaking of each I sum.
my goal not to display all the detail I would like to show that breaking up.
it’s possible to bend the break?
if so, how do I do?
I use version XI 3.1 SP2
Thank you in advance
Smile07 (BOB member since 2010-05-07)
What’s wrong with removing the detail data? Does that cause the results to vary?
Otherwise, there should be a Show/Hide Fold-Unfold toolbar that you can click on. Once it’s showing, you can use that to collapse or expand entire levels.
just an fyi, if u wish to selectively expand or collapse a subsection within a set of sections at the same level, then continue to save the file it will corrupt the file in sp2. you will need to go to fp2.6 to fix this issue, which i have just applied and it does fix this issue.
nick604 (BOB member since 2009-01-13)
the problem that’s not the removing the detail data. and I do not use sections.
I use ruptures.and i have a sum in each foot ruptures.
and my goals I want a report that shows the feet of ruptures and not the details. that’s why I want to fold these ruptures
