Flash object examples
I’m searching for some Flash objects (*.swf) which I can use in my dashboard.
So for example
  • circle object which spins indicating you need to wait
  • arrow that flashes indicating you need to answer a combo box
so basically “moving pictures” anyone some URL’s where you find such stuff?
Tiny :netherlands: (BOB member since 2004-11-10)
Just Google for animated Gif’s. There are thousands of freeware GIF downloads. Also download a freeware GIf to SWF converter. After converting double click the SWF to preview in a browser. Some convert better than others depending on resolution and the original designer. Use the image component to import your new animated SWF into your dashboard project. Wa-La!
If you can’t find the exact gif… make your own or edit an existing animated gif - not hard to do. I edit quite frequently because the gif backgrounds seldom blend in with my dashboard background. Software is out there to do that too.
Enjoy!
datawizard (BOB member since 2015-01-20)
thanks for the tip…
If tried some examples and it works like you described…but…
there’s always a but…
TRANSPARANCY gets lost with most of the GIF to SWF converters
(so it’s translates transparent to white background)
FRAME RATE/SPEED gets lost with most of the GIF to SWF converters
(so it’s sets the moving part to maximum creating a irritating object)
Is there a way to avoid this?
or is ther e a GIF-SWF coverters that takes into account transparency?
UPDATE: found one (VeryDOC) that takes into account transparency but not SPEED so it’s still not 100%…
found some websites which create SWF’s and GIF’s for you (with transperancy background possibilities) on some basic loading icons which you can sometime change color.
Eventually this might give you a nicer/better result then converting GIF to SWF
The one I like most is:
http://www.chimply.com/
second best:
and also this one for the basics
http://www.loadinfo.net/
and basic:
http://www.ajaxload.info/
Yes, I’ve been through those steps and have also used the chimply site. I have also used photo editors to successfully reset the transparency property. I heard that Photoshop does that quite well and many others that allow editing layers. You are right… the background transparency and/or setting to match your background is painful. But when you finally get it you can put some real eye candy in your dashboards to spruce them up.
