I’d like to create a variable called “Obligation FY” that produces a user-defined “year” based on a dimension called “Obligation Date” that falls within a user-defined range. I thought the best means to this end would be an IF, THEN, ELSE statement in the variable’s formula. For instance, IF “Obligation Date” between “10/1/2001” and “9/30/2002” THEN “2002” ELSE IF… Unfortunately, I can’t get the syntax down, which results in syntax errors or incorrect data. I’ve also attempted to change the data type for the “Obligation Date” dimension (e.g., character, numeric, date etc.) prior to creating the variable, which hasn’t helped.
Thanks for such a quick response to my post. Your suggestion worked. This is the syntax I used when the dimension was defined as a “date” data type:
= If Between (‘10/1/1994’ ,‘9/30/1995’) Then “1995” Else If …
Unfortunately, I’ve discovered that if I don’t get the syntax just right relative to the functions (and their associated data types), I can’t seem to get anything to work. For instance, I wanted to add the following ending ELSE to the above statement:
However, the result of the last ELSE statement was the following syntax error:
Just a top tip if you are having problems with syntax. Especially with If…then…Else… statements make sure you enclose every discrete part of the statement in brackets. As you build your formula watch what appears in the ‘Operators’ box on the right hand side. If each discrete statement is correctly built you will see the next required operator appear in this box. If you’ve got something wrong you may only see a bracket or a single speech marks, for example. This is a good pointer to the fact that something is wrong with the statement you have written so far.
This suggestion works. The thing I didn’t realize until I say your solution is that I created a variable (Obligation FY), which is a character data type. Therefore, I think the results that are generated by the variable must also be a character data types
Here’s a fabulous link to a topic in the Reporter forum that Nick Daniels created showing great examples of syntax that can be used to report by various periods of time.
