Finding SQL query from BO canned reports thru SDKs
Is it possible to fetch the SQL queries generated by BO canned reports? I have list of 200 reports saved in my local desktop and I want to fetch the sql queries from them. This is required for documentation purpose. Please let me know if it is possible by using BO SDKs.
maximus82 :india: (BOB member since 2009-08-17)
Welcome to B:bob:B!
[Moderator Note: Moving to SDK - Jansi]
What version of Bus Obj?
I have java code for BOXI R2 that does this but it fetches the reports from the repository, not from a local drive.
jwhite9 :us: (BOB member since 2006-07-28)
Hi Sivaramky,
Give this utility a try:
I use to use it when I need to check queries of many DeskI reports.
Hi Marek Chladny,
Amazing! If you dont mind, could you please explain the basics behind it?
Hi jwhite,
Finding details from repository is also fine, even i have done a small java coding to find the SQLs but facing an error while opening the report document. Getting “unable to load the report” error.
Please share the code that you have written, that would help me to understand. Thanks
The code of the utility opens reports from a specified directory in a loop. In every loop, all data providers of a report are checked and their queries written to a txt file.
