system
1
i have a universe which i generated from a Sap query.
there are a ton of fields with a name that has, for eg, "L01 " in front of it.
i want to rename all those fields by removing those for characters and replace them with null/nothing.
eg change “L01 equipment key” TO “equipment key”
but the replace field in the Find/Replace popup does not allow and empty field. any ideas about how to do this?
dbobcoe (BOB member since 2009-05-15)
system
2
This tool may help.
Joe
joepeters
(BOB member since 2002-08-29)
system
3
ok. thanks. i will take a look at it and try it out.
system
4
What version of Designer are you using? You might be able to redo this by resetting options for default names, but I’ve only seen that in 3.1.
Dave Rathbun
(BOB member since 2002-06-06)
system
5
i have designer 12.1.0.882
