we receive the following intermittent error when connecting to the Financial Consolidation Cube Designer. We use version 10.0.0.333
Any input would be greatly appreciated!
Nico
Nicolas Hadj-Blaha
(BOB member since 2005-03-10)
Nico
Nicolas Hadj-Blaha
Hi Nicolas,
did you resolve this?
Cheers,
B.
bastula
(BOB member since 2008-09-22)
hi
yes we did but I do not remember exactly the resolution - sorry
2 areas to investigate:
Nicolas Hadj-Blaha
Hi Nicolas,
thanks for the quick response and greetings to down under!
The access level shouldn’t be an issue: the user has Admin rights in BOE. Actually the login worked a few days ago, but then we patched BOFC with SP8 Patch 3 and it failed afterwards.
And we only have a single user accessing the system as we are installing and testing.
Do you have any more ideas?
Thanks & regards,
B.
bastula
