Filtering second prompt depending on first prompt
I have a report requirement that if a user enters value in the first prompt then the second prompt should display values related to first prompt only.
for example: dept number: 10 has branch numbers as 11,111,1111 and dept number: 20 has branch numbers as 22,222,2222.
first prompt is enter dept number and users enters it as 10, so the second prompt should display the list values of dept 10 only, i mean it should display 11,111,1111 and the users selects one from this list.
Please help me with the logic for this. I have posted the topic in Universe Designer section as i thought related changes have to be applied in universe only.
tsr_bo (BOB member since 2008-06-13)
Please help me with logic or solution for this issue…
Thanks in advance…
We don’t have many rules on this board so please respect them. Mainly the rule about post bumping:
https://bobj-board.org/tos#heading--bumping
Thank you.
Sorry for post bumping…
We also suggest that you try the FAQ first. :wink:
How do I create cascading or nested prompts?
If you search for cascading or cascad* you will likely find a large number of topics talking about what you are asking to do.
