hi ,
I have all dimension columns in my report and i need to filter first 500 records. Please advice whta needs to be done as i dont have any measure i cannot use rank function.
Thanks in adv
abc
abc (BOB member since 2007-06-05)
hi ,
Thanks in adv
abc
What is the selection criteria? Is it only the first 500? If it is so, I think you can use rowindex()
cyberdude (BOB member since 2007-02-05)
i used row index but i am unable to put a filter it says list of value not available
try row level restriction may be it helps you
Nags (BOB member since 2007-02-07)
could you please tell me what exactly we need to do at row level restrictions
