BusinessObjects Board
Filter (object selector) question
Hello again, team!
I have a list of people. Each person is in this list twice: Once with a “dollars” and a few dollar amounts (for 30, 60, and 90 days) and once with a “quota” for the same periods.
I previously was using two combo boxes in order to get the data I wanted, and it was working fine, but I decided “Hey, why not use a filter?!” which essentially looks like two combo boxes side by side.
Unfortunately, the issue I’ve run into is that it will filter, and then pull the first row that it finds. It will not pull both rows (That is, the quota as well as the dollars). Is there a way to have it return more than one row?
dstone91 (BOB member since 2015-10-29)
Isn’t that the point of a filter? To pull one row out of multiple rows? How about concatenating each pair of rows together and then using a simple combo box?
What is it you are trying to achieve?
Debbie
See, I’ve got a list. It has the following data:
LName    FName    Branch     Total/Quota     30 Days     60 Days     90 Days
Smith    John     Fiji       Total           12          24          36
Smith    John     Fiji       Quota           10          20          30
Jones    Fred     Japan      Total           9           18          27
Jones    Fred     Japan      Quota           10          20          30
etc.
etc.
etc.
There are multiple people in each branch. Each person has an Quota and a Total. When you highlight two rows, it will return two different series in a Bar Chart. If I were to concatenate the rows, then I would only have one series, which is not what I need to do.
I know that I can use a filtered rows combo box to separate it out by branch, and then use another one to select the appropriate employee. However, I was looking to reduce the number of actual objects in the dashboard by using a Filter selector, as opposed to two different combo boxes. Unfortunately, when I use “Filter” it only will return the top row of the two (I.E. it only returns the row with “Total,” when I want it to return both rows with the person’s name.
Use an accordion selector with categories for the Branch selection and labels for the sales persons. Use filtered rows for the output. This will select both rows into the target area and you can connect the target area to be consumed by the chart primary and secondary series.
datawizard (BOB member since 2015-01-20)
Hmmm… That’s a good option, but it doesn’t quite fit the form factor I’m working with. I’ll try and see if I can make it work, though. Thanks!
This may not be a feasible fix for your specific case, but i’d highly recommend the “Essentials Bundle” from Centigon as plugins for Xcelsius/Dashboards. This single relatively inexpensive plugin called “Filtered Summary” really changed the possibilities in my Dashboards. I never had to worry about VLookups/Hlookups/Filtered Selectionsand aggregations as these components augmented the dismal filtering and aggregation techniques that the default components provide. Couldn’t be happier.
— Before someone bans this post for propaganda, i must insist its an honest opinion of a good product meant for resolving some of the OP’s problems
Shobhit_Acharya (BOB member since 2005-08-11)
Bah. Propaganda. Mods pls help!
In all seriousness, though, I haven’t run into any issues with the normal filtering options. I was only wondering if there was a way to make this work better/more easily.
Depending on the size of the block of data, my first instinct would be to use SUMIF and or some lookups to separate out into two blocks, but then I haven’t had breakfast yet…
Accordions are good too, although I really wish you could add more levels in. I do a lot of locational filtering through 5 levels - but now I just use a location dropdown, get the user to select which one they want and then run a real time query to go fetch the exact data set for that location.
Having said that, if what you’re doing already works, why fix what isn’t broken? :mrgreen:
Debbie
“If what you’re doing works” she says…
If only any of my dashboards worked. :wink:
I’m really just trying to give our clients options to see what they like at this point. You know, trying to look busy at work and all that.
Dangerous move! Never give them options! That way madness lies …
I find it’s far better to tell people what they want!
debbie
Unfortunately, a lot of truth in that statement :rotf:
:roll_eyes:
You raise valid points, I’m sure. Good thing the client has only seen one iteration so far, eh?
