Fighting with documents.open and reports full of VB errors
Dear community,
I’m fighting over a week with a dumb problems. I have a Desktop Intelligence Report that is opening and fully documenting all reports within a company.
The error_handling is quite complete because over the time we encounter many “exotic” problems in reports.
The problem is, they have a set of reports, containing VB instructions in on_open event without any basic error_handling method at all that are of course crashing and returns no error to the calling reports.
I know that VB limitations are quite constraining but do you have ANY idea that could, or open the report without triggering VB code in the called report, or returns any error (even a dumb one) without changing the called report upfront (the idea is on this huge amount of reports - more than 10 000 - we will mail to the report owner asking to change those reports after documentation) as we are not able to track those report names because the application crashs
Thanks in advance fellows.
zik (BOB member since 2007-05-23)
