Field identification
We are using BO 5.1.8
An issue has arose regarding the use of a particular field in a number of reports. Is is possible to interrogate BO to find out how many current reports use this field in their data providers?
BoB
boot_hill374 :uk: (BOB member since 2006-01-11)
In the download section of this forum you will find a topic called:
ā€œList objects used in a series of reportsā€
This can be used to do th trick
hth
jbo :monaco: (BOB member since 2005-07-31)
direct link to this post bellow
Having followed the instructions I get the following
Run-time error ā€˜13’
Type mismatch.
The DEBUG button highlights the following line of code:
Set dpCube = DefineCube(dpInterface.DpVBACubes(1)) :?:
The link provided for this report has an author of Dwayne Hoffpauir, EDS.
Could someone please advise as to how I get resolution to this issue.
Do I have to contact the author directly?
If so, how is this done? :?:
I’m here :slight_smile:
The utility has been downloaded nearly 2,000 times, so I’m fairly sure it’s not a general problem. What version of Business Objects are you using? Are you using the same version of the utility (XI versus v5/v6)? Are you able to run other VBA code successfully? In the VB Editor, if you go to Tools, References, is there a Business Objects library selected? If not, that’s the problem.
Hi Dwayne,
Thanks for the reply. It turns out that it must have been a dodgy first download of V5, V6 (we use 5.1.8) so I decided to download it again. This time everything was fine.
The utilty is excellent. Thanks very much.
BoB
