A while back there was a thread on a ‘Fetch out of Sequence’ error while reports were being generated in BusObj but where the error wasn’t occuring in SQL*Plus. I have had a look back at the mails on the archive web site (which is excellent so more of us should use it!) but I want to take this one step further.
I have a fairly simple query (4 objects + 1 condition) which depending on the condition value only returns around 30 rows. The definition of the objects are straight ‘select froms’ with the underlying columns having the following definitions
The condition is on Column4 and the join is from Table1.Col1 to Table2.Col2
The average length of the data in column2 is nearer 200chrs than the max 1900
Anyway, the SQL that BusObj generates runs fine for the majority of the values for the condition column both in BusObj and SQLPlus. On some values however, I get the ‘Fetch out of Sequence’ error message in BusObj but it runs fine in SQLPlus. Now, for those who a) can’t remember the original thread or b) can’t be bothered to look at the archives, one main cause of this behaviour is the Fetch size setting in BusObj being different to the equivalent Arraysize setting in SQLPlus. Changing the SQLPlus setting to be the same (ie 50) results in the error “buffer overflow. Use SET command to reduce ARRAYSIZE or increase MAXDATA.” error. So far so good (ie can get errors in both environments!)
Now, changing the fetchsize in BusObj to the same as the arraysize in SQL*Plus where the query works (ie 15) does not stop the error.
Changing connections from asynchronous to synchronous and keeping connections open etc makes no difference.
Can anyone suggest some changes that can be made or any know resolution to this problem?
p.s The reason for the 2 error messages in the subject of this mail is that the ‘Fetch out of Sequence’ is the error message I get when running the SQL as freehand SQL through a personal connection and the ‘Insufficient Privileges on Underlying Objects of View’ error is the one I get running through a secured connection.
Jonathan
Project Leader
Global Medical, Regulatory and Product Strategy (GMRPS) IS
Did you also try to set the array size on BusObj to 1 ?
A similar problem at one of our customers: They had problems with network routers truncating packets from SQLNet (actually this was a known SQLNet - bug, occures(ed) if IP packet sizes in different router segments do not match…)
Did you run the query directly from SQL*Net over the network? Error ‘Insufficient Privileges on Underlying Objects of View’ lets me assume there are select-rigtht problems in the database.
Hope this helps…
Walter
DI Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna / Austria Tel: +43-1-8151456-12, Fax: +43-1-8151456-21 e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
Interestingly, I went down to a setting of 10 but no lower. I have now worked up from a setting of 1 to 8 and the query now works without an error. From 9 upwards it fails. Thanks, hopefully this will do as a work round at the moment although having such a low setting might well impact the performance of some reports.
with network
known SQLNet - bug,
not match…)
I haven’t tested this (and I’m not sure whether I know how!)
This is the first thing I do with any SQL errors in BusObj. The ‘Insufficient Privs on Underlying objects of View’ seems to be a fairly standard error message in BusObj at the moment and rarely has anything to do with the actual problem. As in this case, the real error is only shown either in SQL*Plus or running across a ‘Personal’ connection in BusObj. Why I get different error messages by running the same SQL through two different types of BusObj connection (pointing to exactly the same Oracle accounts and with the same settings) I really don’t know.
Thanks for your input/solution.
Jonathan
Project Leader
Hope this helps…
Walter
DI Walter Muellner
