system
August 8, 2008, 1:21am
1
I have some 255 Reports for which I need to change the Universes. Just that these Universes exist for different databases. We have one version of the Reports but 2 versions of the Universes. Is there a way to change the WebI Report Universes ( from one to another Version) rather than manually going into the Report Query properties and changing the universes?
Need an answer quite promptly.
Kapil Uppal
kapiluppal (BOB member since 2006-06-15)
system
August 8, 2008, 1:57am
2
As far as I am aware, it is a completely manual process. However sombody may say that it can be done through an API but I don’t know.
plessiusa (BOB member since 2004-03-22)
system
August 8, 2008, 6:03am
3
You should manually change your universe in the report and keep into the public folders and no other option other than this.
Siva.M
looksmee (BOB member since 2006-02-08)
system
August 8, 2008, 6:56am
4
Do we win a prize for promptness then?
dessa (BOB member since 2004-01-29)
system
August 8, 2008, 8:19am
5
Its just like being back at school…
Check out this rather clever method from Mr Rathbun, remebering to take back ups first…
https://bobj-board.org/t/106492
Mak 1 (BOB member since 2005-01-06)
system
August 8, 2008, 8:27am
6
good reply, just hope its not too late.
system
August 8, 2008, 5:16pm
7
You can also use the API/SDK to change the universe on a WebI document.
See attached sample for details.
webi_change_datasource.zip (31.0 KB)
darcstorm (BOB member since 2008-07-22)
system
August 11, 2008, 7:41am
8
Thanks for sharing, good to know there are a number of ways to do this…
Cheers,
Mark.
