system
July 29, 2010, 7:47am
1
I am newbie in BO. i couldnt understand properly fan traps. I have read most of the threads related to fan traps and Dave blog. I partially understood the reason behind fan traps but struggling to resolve .
Can anybody explain to resolve a fan trap by using e-fasion universe so that i can practice the same example in my PC please.
Thanks in advance
krish
kris2727 (BOB member since 2010-07-28)
system
July 29, 2010, 8:07am
2
1.Create an alias for the table that is producing the multiplied aggregation.
2.Create a one to one join between the original table and the alias table.
3.Build the object that is causing the aggregation on the alias tables.
4.Define a context for the original table and a context for the alias.
5.Select File>Parameters and click the SQL tab to display the SQL page.
6.Select the Multiple SQL Statements for Each Measure checkbox.
7.Modify the select statement for the columns that are summed so that the columns in the alias table are summed and not the columns in the original table.
surya_sudheer (BOB member since 2006-11-01)
system
July 29, 2010, 8:17am
3
Have you read this entry in the Designer’s FAQ?
What is a fan trap, why is it a problem, and how do I resolve it?
Dave Rathbun describes it well in his presentation, ZEN and the ART of Universe Design. Which is located here: Dave’s Adventures in Business Intelligence » Conference Presentations
Here is a quick synopsis of Fan Trap from his presentation:
A Fan Trap is a one - many - many relationship. This would happen if you are using a Summary and a Detail table in one query. Fan Traps can cause numbers to multiply. Business O…
system
July 29, 2010, 10:19am
4
Hi Marek.
Thanks for your reply. Sorry to be pain but can you please explain fan trap by using e-fashion and with solution if possible.
i have read those threads and found same solution which is right. But im not able to implement that when i trying to resolve on my own.
kris
system
July 29, 2010, 9:40pm
5
Not sure how else I should describe it than what I have already done:
Hi to everybody…i have 2 simple items in bo universe (2 aggregate indicators) , but when i put them together in a query, Bo think they are incompatible and so the result is this in the picture… he make 2 distinct queryes and then he join…but in pl/sql i usally do only a query, and i have the correct result…what i can do in the designer, to telle that the object are compatible, and that he can do it in only one query? Thanks to everybody!!
[1.JPG]
flavio20002 (BOB member since 2010-03-23)
Yes I have searched QUITE a lot on this forum and I think I have covered most of the posts related to this topic. I saw a lot of posts exlaining how to solve them but haven’t come across any that describe the cause of traps. Here are somethings that I need help with:
Fan Trap:
D1 --< F1 --< F2
Fan trap will not exist if the fact tables above are at the same level of granularity no matter where the dimensions/measures are coming from. Is this a fair statement? If yes, then in real wo…
Dear,
I’m suffering a problem in my universe…I freshly created it and it’s based on an RDB model, not a star-scheme unfortunatelly.
I defined some contexts and alias’ed some tables in order to provide clean operation of the universe.
Today I started creating some reports and all went fine untill the measure (yes, ther’s only 1 numeric in the entire report) started multiplying its value from the moment I started adding more tables to the query…
So in the beginning I started …
I am designing a universe I am facing a issue where for one record I am fetching 7 records and getting huge values , I should get one record. I have checked the all the joins but could not solve the issue. In my date table I have dates from day,week and month is this some thing to do with it needful advice is helpful
thanks in advance
bobtom (BOB member since 2008-01-17)
I have read the article from Dave on fan traps,A->B->C. Does it mean that if B and C have measures in them then it is a fan trap. Or does it have to be a specific on the type of the measures like for example may be total for orders in B and number of orders in C.
hartford27 (BOB member since 2006-11-22)
If we have three tables and the middle table gets a one to many join on one key from another table ie this table being the many side and its get a one to many join on an other key from an other table again this table being on the many side, what are the common issues.
GC_hill (BOB member since 2007-08-29)
And a good explanation of a fan trap by Andreas:
We are facing a Fan Trap problem. We are having 3 tables which are refered in the report. The relation between these tables is as:
CRT_CURRENCY ----< PRC_RATE-----< CAPACITY_DTL.
The data in these tables is as:
Table CRT_CURRENCY:
CCY_CD LNG_DESC
GBP Pound
USD US Dollar
Table PRC_RATE:
RATE_LINE_ID VER_NO CCY_CD TOT_PROMSD_REV
12345 1 GBP 1000
12345 2…
