I am trying to run the configuration tool for BO 6.5.1 and am encountering the below error -> Failed to start node (Error: CFT 06503)
and when i view the log - this is what i see -
OUTPUT>[LOG][111] : updating the configuration file (s)
OUTPUT>[LOG][111] : configuring the ASF services…
OUTPUT>[LOG][111] : starting ORB node…
ERROR>‘E:\APPS\Business’ is not recognized as an internal or external command,
ERROR>operable program or batch file.
OUTPUT>[ERROR][503] : Failed to start node
I have done the server installation at
E:\APPS\Business Objects\BusinessObjects 6.5.1
In the previous posts I got to know that we cannot use the standard path. I earlier had it installed in E:\APPS\Program Files\Business Objects\BusinessObjects 6.5.1, but after going through one of the posts, i uninstalled and had it installed again in E:\APPS\Program Files\Business Objects\BusinessObjects 6.5.1
But am getting the same error. Any thoughts or insights is highly appreciated.
Is the path causing the problem (path has names with spaces)
Did something go wrong in the server installation?
I am now done with the configurationa and supervisor setup.
I am now able to open the BO admin through console and access the documents, but i get page cannot be displayed when i try through the URLS -
It’s 6x, did you go into the configuration tool (forget what it’s called) and deploy your webserver / appserver? Did you choose IIS or Tomcat?
I think that’s the part 2 of the install - install it all, then configure your node (master node for just a single server) - that puts you into all the setup screens you’ll need next.
In 3x it just happens, in 6x you do that manually - lets you add servers to existing clusters, move stuff around…
