system
1
Can someone help me on this Extractor Error ? I am going mad.
(14.0) 09-05-12 04:01:40 (E) (5512:4616) VAL-030977: |Data flow DF_Acq_0CostElmnt_Attr_D_CORP_ECC|Reader qry_metadata-Mapping1
Extractor returned error: <E: MESSAGE - Error while extracting data: DataSource 0COSTELMNT_ATTR, package 000000. MESSAGE_V1 -
0COSTELMNT_ATTR. MESSAGE_V2 - 000000. E: MESSAGE - Error in data extraction (extractor RSA3_GEN_GET_DATA). MESSAGE_V1 -
RSA3_GEN_GET_DATA.>.
ganeshxp
(BOB member since 2008-07-17)
system
2
I bit more info please.
Has it ever worked for you, or are you using this for the first time ?
I’m using that extractor in production without any issues.
Leigh Kennedy
(BOB member since 2012-01-17)
system
3
It was working until SAP Team applied a Service Pack…
ganeshxp
system
4
Two things I would try:
Reimport the metadata. I had an issue a few months back where after a patch one of my extractors went funny. I reimported and it worked again.
Assuming you are doing delta loads, re-initialise and do a full load.
If you can’t do a full load, log a case. You might want to review the notes in here (http://wiki.sdn.sap.com/wiki/display/EIM/Installing+ODP+and+keeping+it+current ) yourself as I have found it takes weeks to get answers on extractors…
Good luck !
Leigh Kennedy
system
5
re-import doesn’t helped.
Thanks for the quick link. I will check with the SAP Folks.
Is there a way for me to check if these notes are applied to the system or not?
ganeshxp
system
6
I get my basis people to do that. I’m not sure how they do it…
Leigh Kennedy
system
7
Okay the Full Load cleared this glitch…
But why should I do a Full Load? Is this a reproducible/non-reproducible bug for Extractors/SAP System?
ganeshxp
system
8
I don’t know why we should have to, just that its worked for me in the past. Glad it did for you !
Hopefully Werner can shed some light on this ?
Leigh Kennedy
