In my experience, using Open Hubs for data extraction from BW has a couple of disadvantages. The first is that it is significantly slower than ABAP extraction. The second is that Open Hubs are not ideal for large volumes of data. If you only need to load 500k records this won’t be a problem, but if you need to load 100MM records it will be. The third and last is that it is necessary to customize BW in order to be able to use Open Hubs. More specifically, you need at least an Open Hub table, a process chain, a DTP and a transformation.
However, Open Hubs offer one big advantage over ABAP dataflows: delta support. If you need this, Open Hubs are probably the way to go.
Hi Werner, is SAP going to do anything about low performance of OpenHub-based load?
As for extraction from cubes, it seems like the better option (because OHD is ungodly slow) would be to shove the data into an intermediary table/DSO and then fetch it via ABAP flow.
