Extracting From Data Cube
Is it possible to use ReportScript to extract one or two fields from the results of a business objects query? Is it possible to extract from the data cube?
Do the BOResults or BOVariables class permit this?
Thanks in advance
-Michael
Michael wrote -
Michael,
I’m not sure if this is exactly what you’re after but it may help. The following script called get_dates extracts 2 values from the first data provider in a document. This particular data provider has only 1 row with 2 columns.
Sub Main
dim start_date as String
dim end_date as String
start_date =
ActiveDocument.DataProviders.Item(1).Columns.Item(1).Item(1) end_date = ActiveDocument.DataProviders.Item(1).Columns.Item(2).Item(1) Application.Variables.Item(“startdate”).Value = start_date Application.Variables.Item(“enddate”).Value = end_date End Sub
To access the values you can create objects defined as ‘@script(‘startdate’,‘A’,‘get_dates’)’ and @script(‘enddate’,‘A’,‘get_dates’)
I hope this is of some help.
Best Regards,
Ailie Forgie.
Hi Michael:
There is a script at my site at www.bobooks.com that creates labels from the contents of the Microcube. Have a look it may help you out.
Robert
Schmidt Interactive Software, Inc.
Michael wrote -
