Extract tables and columns and joins from Crystal Report
I have a bunch of crystal reports and i just need to extract what tables and columns they use and their joins. Is that possible? Kind of like Universe Documentor (Extractor) utility that i have seen on these forums.
Thanks in advance.
NycPriya (BOB member since 2010-11-04)
Not that I’ve found, at least not for freehand SQL queries.
Going into each one and looking at the SQL seems the only way.
Thanks Mark, actually its easier for me to do that with Freehand SQL reports, its the ones that have tables imported in, i want to document.
There is a way to get to this using either the Java or the .NET SDK. I have a sample on my website of how to use the .NET SDK, but it’s using an older version of the SDK - I haven’t upgraded it from VS 2008 and Crystal 2008. It would get you started, though.
Look for “Code for CrystalDocumenter application” at http://www.dellstinnett.com/sample_code.html.
-Dell
oh Dell, you are an awesome person, if only i was even a little literate on how to use .net and sdk lol, thanks much :slight_smile: i guess its time to start learning…
