system
August 1, 2003, 11:12am
#1
Hi, i have a report with 2 Data Providers. my user need to export this report into excel file. if i am using BO’s export format it exports the data provider wise. so the data in excel file is different form what i am showing in the report. how to export the Report to excel with out changing the format. Please help me …
by
sasikumar
Sasikumar.M (BOB member since 2003-08-01)
system
August 1, 2003, 11:18am
#2
by
sasikumar
Have a Look here Reporter FAQ
Sri
Sridharan (BOB member since 2002-11-08)
system
August 1, 2003, 11:23am
#3
Or alternatively save as HTML document and open that through Excel.
Dezza
dezza (BOB member since 2003-06-10)
system
August 1, 2003, 11:25am
#4
If you have version 6 then Save as XLS comes as standard and preserves formatting.
Nick Daniels (BOB member since 2002-08-15)
MarkP
August 1, 2003, 1:10pm
#5
Have you tried the export script from the BOB Downloads section?
system
August 2, 2003, 1:23am
#6
Have you tried going to the menu bar, click on Edit>Select All. Go to Excel and hit Ctrl V. This should copy the data as you see it on the report.
Jim (BOB member since 2003-02-14)
system
August 4, 2003, 1:41pm
#7
That should be Edit–>Copy All…
norty303 (BOB member since 2003-03-19)
