HI,
How to export reports,Exported reports must have option to be encrypted and compressed (WinZip functionality).
Naveen Vanaparthi (BOB member since 2008-07-02)
HI,
You can’t encrypt and compress from inside Crystal itself. You would have to either do that part manually or write a program that will handle it for you - the program can export the report from Crystal and then encrypt and compress it.
-Dell
hilfy (BOB member since 2007-04-16)
I think that you can do this with the APOS Report Package Booster. It’s a 3rd party add-on tool…
MJRBIM (BOB member since 2007-03-23)
Hi, folks, a couple of posts have been removed from this topic after being reported for advertising. Please remember that if you are going to mention or link to a product put out by your own company you need to either provide a free version, or provide something else of value in the post. Our posting rules and guidelines prohibit entering a post only to provide advertising for your products and services.
