Using a trial version of Crystal Xcelcius 4.5,
Trying to export to BOE, the option is grey out. Do you need an licensed version before you can export to BOE?
rs
rs90144 (BOB member since 2006-04-18)
rs
A belated answer but I see the same thing using the trial version. Too bad
Nick Daniels (BOB member since 2002-08-15)
No, I test the trial version of Crystal Xcelsius Workgroup Edition and it allows to export to BOE
Blacksmith (BOB member since 2005-04-12)
That makes sense, I am just demoing the professional version.
can someone please tell me where is the option to export it to BOE as I do not see it?
P.S: I am using trial version
Also, can components be refreshed automatically w/.o refreshing the data model?
-peace
P34C3 (BOB member since 2005-11-30)
1.Check this post by bension and see which version you are using and see if that version allows you to do what you wanted?https://bobj-board.org/t/86960
2.Attached is the screenshot where you can find option to export to BOE.
3.What instruments are you trying to refresh??
a)If you using webservices(QaaWS)/Live Office/data from XML (using XML maps) to populate instruments , then YES, you can refresh instruments without refreshing the whole model.
b)If you are using just some static data from excel, then NO, you cannot update instrument until you refresh the whole model.
bambazooka (BOB member since 2007-01-26)
