I was heavily looking for a possibility to export Metadata Management objects gained from a SAP BW (NW 7.4) system? This question is combined with the challange whether there is a bidirectional way to directly extract those metadata to a SAP PowerDesigner system (16.6). I know that there’s the unidirectional way from PD to IS via PD Integrator.
you can use the \InformationSteward\MM\bin\MMObjectExporter.bat to export the objects to XML file
depending on the metadata, the file size will be big, you can check the content of the XML file and see if you can process that, you can try using the objectType xsd but I there is some issue with that, or you can also create your own XSD from the XML
run the utility with following args
MMObjectExporter.bat boeServer CMSSERVER boeUser Administrator boePassword ADMINPASSWORD boeAuthentication secEterprise configuration COFIGNAMEORID filename C:\temp\object_export.xml
replace values in upper case with the values from your env
or
you can also, get the metadata from MMD_BW* views and MMD_Relationship vew
COFIGNAMEORID - Name of Integrator Source Configuration that you have created to collect BW Metadata in CMC under Information Steward ->MetadataManagement->Integrator Sources
or you can pass the configuration_id of this Integrator source, you can get the configuration_id from MMD_Configuration view check the business_name will be same as the integrator source name
